Engine Torque
gregjo1948
I need the head bolt torque spec and valve clearance for a 2004 Cub Cadet LT1042 13BX11CG710 . It has a one cylinder Kohler engine. There is no Kohler engine tag to be found.Thank you, gregjo1948
If anyone knows it would be Mr. Rivets he should be on here sometime I bet he can help you with that question.
