Engine TORO ZTR Z560 warner electric clutch issues
Brocky
Hi Everyone
Just wondering if anyone has had issues with their Toro Z560 Zero Turn Electric PTO Clutch.
My Engine starts but when engaging the PTO the engine decelerates to a stall with no turning of PTO or blades. The PTO is intact and electrics all OK. I can hear the PTO engage in and out when operating the switch but when engaged the engine comes to a stop.
I dis-assembled the PTO thinking it may be a bearing but the 2 bearings move freely.
Can anyone suggest anything as it is expensive to troubleshoot by replacement. The clutch is a Warner 5218-99.
Many thanks in advance.
Mark
066
check blades & bearings on the cutter deck to see if they spin freely without the belt on the pulleys also check idler pulleys on the top side of the deck.
Brocky
HI 066.
I forgot to mention that the belts and deck spin freely when disconnected from the PTO clutch pulley.
Thankyou for your reply.
Mark
pugaltitude
Do you mean the engine cuts out as soon as you engage the
Electric clutch?
That could be a safety switch problem like the seat switch.
Brocky
Electric clutch?
Thankyou Pugaltitude
You were on the Money. After charging Flat battery I found that the Seat switch was playing up. I cycled it a few times and now I have a working mower.
All happy.
Mark
