I am having a problem with the blades not being even with one another. It has a two blade system, which i will call "drivers side and passenger side". I am noticing that the passenger side blade is cutting at a higher level then the drivers side blade. The difference in height between the two blades when they are in line with one another is 7/8''. I have replaced the blades and the blade stiffeners hoping for a cheap fix. After putting the new blades on i noticed there is still a difference in height between the blades when they are in line with one another. Are the blades suppose to be this way? Why am i getting a different cut height difference? PLEASE HELP!!! yard looks striped only because of the cut height difference between the two blades. :confused2: example of the height difference passenger side> ----____ <drivers side
