Hello all, First message on this forum. Please be patient with me.
I have a 2003 Toro Z286E Z-Master with 62" deck. Possibly what was called the GROUNDSKEEPER deck. 800 hours on the machine. New Gauge wheel axle bolts snap when replaced.
The tang that the axle bolt attaches to has been bent but straightened as best as possible. I am now using deck without these anti-scalp wheels but obviously the deck tends to scalp and gouge in certain areas.
I am sure that others have had this same problem. Has toro retrofitted an improved system that I can purchase for my deck? Any other comments would be appreciated. At the end of the season I was planning on hAving a second plate welded on at each wheel site to provide an axle blot that will be supported on both sides. Before I do this I will have to find out what is available as far as wheels and bolts that will make this change work.
Thanks for any comments.
Chuck E.
Chuck E.
