Toro Wheelhorse
kdalager
My Toro Wheelhorse with a 15.5 Briggs engine leaks oil after I have changed oil - it leaks until it reaches the add oil level and then stops. Am I correct in assuming the upper level oil pan gasket is causing the leak - or is it something else?
briggs
to me its sounds like the base gasket is leaking
