Toro Wheelhorse Won't Start - Need Help
Gregooch
I have a twelve year old Wheelhorse mower/mulcher with 16 HP B&S engine. A few years ago the carb became gummed up and it was leaking gasoline. My engine guy rebuilt it and added a fuel shutoff to prevent leaking gasoline in the future. It has been working fine since but now does not want to start. It cranks and cranks and has started the first few times then shuts off after about 1-2 minutes and after that only cranks but will not start. Any ideas why it won't start and what I can do?
Lawnboy18
I would check the carb again. It must be gummed up again. Clean it with carb cleaner and reinstall correctly with the right gaskets.
Or it might be your fuel shut off that is on the off position.
