I have a 2015 Toro V-twin (with 225 hrs) and it seems the compression release may not be working. I have checked the battery and all connections. Spins fine with no spark plugs. I have adjusted the valves to the tight end of specs .004 inch intake, .006 inch exhaust. It still mostly stops when I try to crank it. Does anyone know how the CR works on Toro branded engine or if I can tell if the CR is working without taking engine apart? Should there be a visible "bump" of one of the valves from a mechanism on the cam?
