hi all,
my toro 16-38 XL rider has a problem; you have to run it on half choke, otherwise the governor with go back and forth making the engine rev and die down over and over. it happens all the way from low to high but evens out at half choke. i have replaced all the gaskets. how could i stop it? (fix it for real)
also, there is a little wire (2 of them) that connect to the the bottom of the bowl that houses the float on the carberauetor. what does it do? control the jets? there arn't any exposed jets from the outside at all.
could it just not be getting enought gas?
thank you.
