Toro Super Recycler-- self-propel adjustment stuck
Yabadabadoo
  • / Toro Super Recycler-- self-propel adjustment stuck
I'm talking about the from the handle cable to the rear gearbox will not move the engagement adjuster its attached to. The cable is fine, unhooked it from the adjuster and manually still get it to move. Opened up the gearbox and couldn't make it move from the inside either. Hesitant to take all the gears out cause sure it's not a gear issue---- cant dope out why the adjuster wont budge. Anyone with any thoughts, wouldn't expect such a simple thing to be so perplexing
HELP, COVID has struck our ability to see which of the hundreds of different selp propelled models Toro makes you have. We need your help to at least know which model you have. Make sure you include both model and serial numbers for the unit.. if COVID doesn’t get worst maybe someone will be able to help you. Remember we’re service techs not psychic’s.
