Repairs Toro super recycler locking rear wheels when pulled back.
Caseman
I just picked this mower up used and I'm trying to figure out what the problem is.. The guy said it's 5 years old and could use a belt . It has newer drive tires.
Model 90092
The mower locks the rear wheels then trying to pull it back.
From the searching I did I found it could be. The rocker keys .
I took apart the left side which was also the one clicking and cleaned them all up. The pinion gear is very worn. And now that I think of it I don't recall seeing the friction on the left side. (maybe I missed it.)And reinstalled it with wd-40 temporary. The right side had no wear on the pinion gear.
On to the questions .
Am I on the right track thinking this is the issue?
Should I buy
http://www.ebay.com/itm/GENUINE-OEM...691125?hash=item41a39a94f5:g:tGwAAOSwCypWpDEC
Or do I just get what's needed.. I'm not really sure what wears out on this stiff.
I am also buying a belt.
Last question what do I lube the pinion gears up with?
Thanks in advance ..
I just got home from work at 2.30 am and couldn't wait to check. But I was right there was no rubber friction thing on the left side. Which is the side that has the very worn pinion gear.
