After an episode where I got into some boggy ground and got the mower mired down and had to pull it out the mower won`t go. Starts fine. The mower belt seems to work fine but the machine will not go forwar or reverse. Any help out there?
I did not go through the setup procedure for pushing the mower before I pulled it out of the mud. But all I did was to pull it sideways to get it facing out. It was then that I realized I had not set it up for pushing so I did that (by the book). After I pushed it a short didtance I then started the mower. It was now set up to run with the small rods pulled out and locked in teh run position. Everything worked fine just no locomotion either forward or reverse. Stymied.
