Toro self propelled mower, Briggs Stratton engine
Y2keddie
I have a hard time starting this engine. The motor shaft seems to seize /lock up. After mowing for 1/2 hour, I stop the engine via brake/ground mechanism. If I try to restart, the pull cord will not pull. If I try electric start, the starter will engage and try to spin but can not. I pull the plug wire and can not spin the blade. If I turn the blade the opposite direction it will in seize and then turn freely in the right direction. Then the engine will start.
I thought maybe the drive belt might be stuck, so I took it off. It still won’t spin. It’s like a bad bearing, but it always frees up if I move the blade backward and fro. Then the engine runs fine for another mowing.
Today again it locked up after mowing,I moved the blade again. Then I put the belt back on, it started, and I mowed again.
The crankcase has plenty of oil,and it dosen’t Use any oil.
This is driving me crazy. I wonder if it’s an engine problem, possibly a bearing, or maybe the engine shaft mounted pulley has debrie under it causing it to drag against the motor base. When the shaft turns freely I can slide a feeler gauge under the pulley and find no interferance. I checked the braking mechanism and it’s not engaged.
Any ideas?
Russ2251
Sounds like a sticking flywheel brake.
Make sure brake is releasing when bail is pulled.
You may have to remove the top engine cowling to get a good visual.
Y2keddie
Brake is releasing
