Toro recycler 6hp self propelled mower just died and won't restart
Mharnisch
I was mowing today with my toro recycler model 20042 6hp GTS Briggs & Stratton engine when it just stopped dead. There was no warning such as sputtering. It just stopped like I hit a big rock, which I didn't, and the brake did not engage. I tried to restart it to no avail. Of course I checked the gas, loose spark plug wire, etc., but all was ok. Has anyone had a similar problem and found a solution to fix?
ignition coil: do you have spark?
I confirmed I had spark, compression, and gas up to the carburetor. So I disassembled the carb, cleaned out all the holes, reassembled, and it started right away. Apparently it was plugged somewhere. What is strange is that at the beginning of summer, I installed a gas filter. This mower, which is many years old, never had a filter and I never had any problems. Go figure. Anyway, thanks for your suggestion.
