Toro LX426
ywillia
Good day,
I have a Toro LX426 and every time I cut the lawn the cutting belt slips off and the mower is not as fast as it use to be. What could be the problem? please help
chance123
Good day,
Check your belt guides and your belt might also be worn out. A worn V-belt will not ride the V surfaces of the pulley. It will ride in the bottom of the pulley and slip
Also check to see that the idler pulley bearing is not worn and rocking.
