Repairs Toro Groundsmaster 7210
Walshy
Hi guys,
My groundsmaster 7210 is shutting down after half hour of normal operation without any issues. It's starting fine again after it shuts down and is shutting down when the control levers are moved out of the neutral position.
Has anyone experienced this issue before?
Thanks
First thing I would check is the seat safety switch. Both conditions will result if the switch is not operating properly.
Thanks I will have a look at the seat switch and handbrake switch. It's very odd that they work fine on a cold startup and after half hour or so something starts playing up.
Brake switch will do that too. Its a pia to get to. Sometimes debris will build up causing it to trip.
