MabletonMower
- May 2, 2014
- 1
- 2
My 10 year old toro self propelled lawn mower (model 20016) was having issues with the self propel feature. I tried to change the belt and the new belt freed up the stuck wheels but it was still making a bad sound and though the wheel were slightly powered when lifted in the air they stopped when they were on the ground. I decided to change the transmission which I think I have done with the exception of the last step. The belt spins a pulley which sits on a drive shaft that goes to the transmission. The pulley is attached to this drive shaft via a nut and washer. The problem I'm having is that I can't tighten the nut because when I try to tighten it the drive shaft just spins instead. I don't see any way of stopping the drive shaft from spinning. Stopping the wheels still allows the drive shaft to spin. grabbing the drive shaft with pliers would be almost impossible due to space limitations, and I think it would damage the threads. There must be a trick to this. Anyone have any suggestions?
Here is the parts diagram I'm talking about. The nut I'm trying to tighten is #25.
Toro |
Toro |
