After cleaning the carburetor it started right away; only do die out after 5 seconds. It would not start again. Since it started once I figured that the coil is probably okay. The air filter is clean. The spark plug looks good; but dry. I expected to see it wet with gas. I want to check the coil; but haven't yet figured how to get to it.
