toro 6.5 self-pro
rts
Mower is blowing white smoke and leaking oil from the exhaust won't stay running...
Lawnranger
Check your oil level and if it's overfull, drain it all out and check the carburetor needle & seat to see if it is leaking. After you fix the problem refill with the proper spec. oil and try again. You may need to clean you spark plug with a wire brush and re-gap to spec.
