Greetings from SC
I have rebuilt the carb on my Toro 51932 trimmer. It has a Walbro WYJ 345 carb with remote primer bulb. I replaced fuel filter, lines, plug etc. I think the lines are connected right. I understand that the primer bulb pulls fuel thru the carb. Im not sure which is the inlet / outlet on carb.
My question is which is inlet which is outlet # 1 or # 2
Thanks
Thanks
