When I push the left control arm outward the black plastic box is trying to run?
O OILMAN Forum Newbie Joined Jan 28, 2018 Threads 1 Messages 2 Jan 28, 2018 / Toro 4235 #1 When I push the left control arm outward the black plastic box is trying to run?
7394 Lawn Pro Joined Sep 5, 2014 Threads 89 Messages 5,068 Jan 28, 2018 / Toro 4235 #2 What black plastic box are you exactly referring to ?
O OILMAN Forum Newbie Joined Jan 28, 2018 Threads 1 Messages 2 Jan 29, 2018 / Toro 4235 #3 7394 said: What black plastic box are you exactly referring to ? Click to expand... It is the brake control
BlazNT Lawn Pro Joined Apr 26, 2012 Threads 28 Messages 6,973 Jan 29, 2018 / Toro 4235 #4 So you need to know how to adjust your brakes?
7394 Lawn Pro Joined Sep 5, 2014 Threads 89 Messages 5,068 Jan 29, 2018 / Toro 4235 #5 OILMAN said: When I push the left control arm outward the black plastic box is trying to run? Click to expand... Is this happening when you are shutting off the machine or starting it, by any chance ? Cause that sounds like the parking brake is setting itself. Is it just a short quick noise ?
