Export thread
Toro 223D engine problem
#1
Hdonly
Hdonly
Hello all. New to the forum. I am having some problems starting my 223D with the Mitsubishi diesel engine. It is hard to start and smokes lots of black smoke when it does finally start. Smoke clears up once it is running. I have replaced the fuel filter and air filter. It has been slow to start since I got it last fall. Seems to be worse, but it is also colder outside. I replaced the battery. I ordered a new starter as it still seems to turn over slow with the new battery. I'm hoping it is just turning over too slow and the new starter will fix it. If not, I am thinking one or more injectors may be dribbling fuel instead of spraying correctly. The glow plugs get hot so I think they are ok. I have to keep the glow plug switch on longer that the book says while cranking the engine. It acts like a gas motor when it's half flooding. Opinions?00y0y_7uR9YI5Ax8Y_1200x900.jpg00r0r_1BBXFC9MW0h_1200x900.jpg00G0G_dzztTKsEsHP_1200x900.jpg00e0e_676wSvS3Lip_1200x900.jpg
#2
BlazNT
BlazNT
Black smoke is too much fuel for air. I would say the injectors are fine especially if it clears up. Old diesel engines love to blow black smoke till they warm up a little. My mower does not allow glow plugs to run during cranking. Heat it up then start it.
Get a bigger battery. 475 CCA min. You need a car battery.
#3
Hdonly
Hdonly
Installed a 525cca Excide battery yesterday. No real change in cranking speed. I can hold the glow plug switch on. Still starts hard and blows lots of black smoke when it finally does start. I ordered a new starter (from DB) Wednesday night. It actually just came to my door about 15 minutes ago. Going to change oil and the starter tomorrow morning.
#4
Hdonly
Hdonly
Went out this afternoon and messed with the TORO a little since it was kinda cold. My book says to hold the glow plug switch 10 seconds when above 40 degrees. I went ahead and held it on for 20 seconds, then hit the starter. Didn't start quick, but it started better than it has been. Not knowing how long the battery sat on the shelf at the store, I put the charger on it for a while before attempting a start. I think I will still put the new starter on it tomorrow. I can always keep the old one for a spare. Oil is really black so it gets changed also. I have no idea how much time is on it. Going to change the drive oil also. From my book it looks like 10w30 SF/CC or CD is good in both the engine and drive. I have new filters for both. I had to change the rear yoke on the mower driveshaft as it broke when the u-joint came apart. Looked like the rear joint has never seen a grease gun. Changed both joints also. Greased the entire machine, changed coolant and have some new tires to put on it. Think I might as well put a paint job on it while I am at it. My plan is to take a lot better care of it than the previous owner did. Also found two of the bolts missing on the muffler where it bolts to the manifold. I think I got it just in time to save it and make a good reliable mower out of it.
#5
EngineMan
EngineMan
If it was I, I would replace the glow plug(s)
#6
Hdonly
Hdonly
Just ordered glow plugs from ebay. Ad stated "set of 4" for $24.23. I thought "Wow, cheaper to buy 4 than 1 on several places I looked". When I got my order confirmation email , it stated "package of one". Yes, I turned around and cancelled that order. Turned around and ordered them from Sparkplugs.com. Some shady goings-on on ebay.
#7
Hdonly
Hdonly
Well. i ordered some glow plugs. I got out after the rain today and changed the oil and filter. Got to fiddling around the engine while it was draining. Found that aluminum connector that goes across the glow plugs was split at one end and loose under the nut. I pulled the nut off, straightened the connector, added a washer and I was off to the races. Engine started much better. I was only using two glow plugs. Now I had three. Now I have three spares. Thank you all.
#8
EngineMan
EngineMan
At sometime you will need them, good to know its up and running better and you did check it out...!:thumbsup:
#9
Hdonly
Hdonly
I just can't believe I missed that being loose. I even checked for voltage at each glow plug. I guess, like many bad connections, it would show voltage on the meter, but fail when the load was put to it. It will re-start when warm now, as it has the timer box on the plugs that is tied in to the starter circuit. Change the hydraulic oil and I am ready for the grass to start growing again. Thanks again all.
#10
Hdonly
Hdonly
I know this is a little old. My 223D got to the point it wouldn't start at all. The glow plugs I ordered were the wrong parts-too long. I pulled all three of the old ones out and put 12 volts to them. All three heated up quick. Put them back in. The starter I had ordered was also wrong. Had to send it back. I just recently found the correct starter.Put it on and the engine starts like a new one. About 5 seconds on the glow plug switch, 3/4 open on the throttle and it fires right up with near no smoke. I am finally happy with my Toro.
#11
EngineMan
EngineMan
Getting the wrong parts can be a pain I know, you did the right by testing the plugs nice to know its all working out, thanks for letting us know the update:thumbsup:
#12
Hdonly
Hdonly
Before, I had trouble starting even when warm, I had to hold the glowplug switch down. Now when warm, all I have to do is hit the starter, and it fires right up. That extra speed from the new starter has made it seem like I put a new engine in it. And no smoke when starting. Discovered my steering cylinder is now leaking. Going to get underneath it today and see if it's the cylinder or a hose leaking. Even with all the little things I have had to fix, this is by far the best mower I have ever owned.00101_heKy1wJm18C_600x450.jpg
#13
EngineMan
EngineMan
Am sure you will able to replace the cylinder seals and O-rings or replace the bad pipe (hose) lots of videos on utube..!
#14
Hdonly
Hdonly
Well, the Toro 223D is back to almost not starting. Cold, I have to grind on the starter a long time with tons of black smoke. I have to play with the throttle and the glow plugs while cranking. Once (and if) it finally starts, lots of black smoke then finally clearing up. Retorqed the head, reset valves, replaced injector nozzles. No change. Could the injector pump itself be the problem. It seems to be getting progressively worse. I have a Dahatsu diesel engine in a Toro Z Master parts machine that runs good. Thinking about giving up on the Mitsubishi and swap the Dahatsu in.
#15
Hdonly
Hdonly
Service book on Mitsubishi L3E engine in trouble shooting section, says the first thing to check for excessive black smoke is adjust smoke set. No where in the manual can I find hoe to adjust smoke set. Anyone have any idea what they are talking about?Screenshot from 2024-04-21 07-29-55.png
