prchandler
- Nov 13, 2014
- 1
- 1
I have a Toro model 20071 22" recycler with a Tecumseh LV195EA engine. Using a spark plug/ignition tester, I have verified that I have spark when the tester is grounded to the engine. However, when I connect the tester to the spark plug, the tester does not show any spark. I have used two brand new spark plugs to test, so I don't think it is an issue with the plug. What else should I be checking?
