Ok, so I purchased a nearly-new Toro 20371 used off Craigslist in December of 2013. Started on 3rd pull. Like an idiot, I left the gas in the tank - never winterized the machine. Now I'm paying the price. This mower looks practically brand new. Here is what I can tell you:
1. the mower won't start
2. I've got a spark when I pull the chord
3. If I remove the spark plug, and drop a few teaspoons of gas in the chamber, the machine will start, then die once that gas burns off.
4. The fuel line from the tank to the carb is clear.
5. I removed the carb bowl, and there was a small amount of varnish - which I cleaned up.
6. I cleared all bad gas from the machine, added fresh gas - it still wont start.
I have not tried to replace the spark plug. One youtube video I saw on this same machine with similar issues showed that a simple spark plug replacement is all it took.
I would clean the carb but can't figure out how to remove it. Also, I should mention that I've noticed the cables must have been pinched during my move to a new home. Not sure if that is an issue or not.
Anyway, I'm looking for some insight. Did I provide enough information? I would remove the carb and clean it or replace it. But I cant find the instructions on how to do that anywhere.
Thanks in advance.
Thanks in advance.
