Toro 20334 smokes/stops when it is tilted to it's sides
sil21
  • / Toro 20334 smokes/stops when it is tilted to it's sides
The mower is about one-year old. It smokes when tilted to it's sides on slopes of less than 15 degrees. It would stop unless it was paused. Why?
possum
I would check to see if the oil is overfull.
Does it do it when going both directions, carb on the up side and carb on the down side?
sil21
Thank you for the reply. As I recall at the moment, it happened on one direction. I'll pay more attention next time.
I'll bet it happens with the carb down, due to the fact that when the engine is tipped that way oil will enter the breather chamber and then sucked into the carb. This is not uncommon when the mower is tipped that way. Only way to solve is to only mow with the carb up.
sil21
Thanks Rivets. I mowed w/ carb side up this week. It seemed to work. I did not have this problem when using Sears and Montgomery Ward mowers before on the same slope. Is there a mechanical way to rectify the problem w/ this Toro mower?
Sorry, but that's the nature of today's mowers. Have you made sure that your oil level is not too high. This would cause the problem to occur quicker. I also have a hill and I cheat. I keep the oil level a little low, but make sure I check the level every time I use it. I don't recommend this for anyone else, because I can repair my units a lot cheaper.
sil21
Thank you for sharing your knowledge.
