Hi guys! saw some good threads using the search here, but nothing quite to solve my problem.
A couple months ago, my Toro 20332 found a metal spike on a railroad tie in my back yard. It instantly killed my mower, and i was never able to get it to start. The blade would come loose trying to start it. After some research, i found out i may have sheared off the pin to the blade assembly hub underneath.
Sure did! And thankfully a good friend had one of these mowers sitting in his garage for parts. I replaced the blade assembly, and mower backfired and spurted a bunch, never starting.
After doing some reading, i found the cylinder may be full of oil and gas. I pulled the plug and turned over the engine a very great amount, pulled the carb apart and cleaned it, inspected 4 week old air filter.
Now the mower starts, but after several knocking noises and 5-6 pulls. Once its running, it sounds brand new. I proceeded to mow the yard with it, and it did fine without regards to the 5-6 pulls it takes to start it. The knocking noise also scares me. Anyone have a clue what this might be? The crankshaft appears to be true, but i dont have a better way to test it other than a visual inspection.
Sorry for the long post
