Anachronomer
- May 1, 2013
- 1
- 6
Hello. I tried to start my Toro SR-210SB (The only information on the engine I can find is that it is a "GTS-200 OHV", I can't find the manufacturer) for the first time this spring and found that if I pull fast on the starter rope, it refuses to turn over. If I pull slow and hard, I can get it to turn over, but it is very difficult. I can not crank it fast enough for it to even try to start. I removed the spark plug, and with the plug out, it cranks smoothly and easily. Based on that, I assumed that a valve was stuck. I pulled the rocker cover off, and noticed that the valves move freely. I pulled the cylinder head off and found that the piston and valves look super clean and move perfectly. That exhausted my troubleshooting ability, which is why I'm here.
To summarize:
- Very hard to turn over with spark plug installed
- Turns over smoothly and easily with spark plug removed
- Valves are clean and move well.
- I'm over my head with this one.
The only additional details that I can think might possibly be related are that I stored it over winter in a shed instead of the garage, but either way it always freezes over winter. It didn't get wet or anything like that.
Thanks for any help or suggestions.
To summarize:
