Tires
Jim Pritchrd
I have an IS2100Z Series with 24x9.5-12 tires and looking at putting a bigger lug tire on because of slipping in wet grass and on hills. Recommendations? Can I use a 24x12-12 on this mower?
Ken22
That's a 2 1/2" difference. I'm not a professional mower with a little off road experience. I see new rims and probably spacers if you can't find rims with enough offset. That's a heavy machine there would be more stress on the drives especially the bearings.
Its Me
12 PSI on those tires, stay out of wet grass if at all possible, hard on the mower and grass cut don't look good, bought a used Turf Tiger Scag with the tractor tires on the rear, rides terrible, will check grass on turns if not very careful, don't like them at all., Joe
