I’m sorry didn’t mean to offend you. I called Cub the other day. It wasn’t that I didn’t like their answer. Most manuals list their own recommended tire pressures and not state what’s recommended on the sidewall. I’m sorry if I wasn’t clear, wasn’t insinuating that you were not a help, just poor wording on my part. Your recommendation is right at what I have now. Just looking for what others are doing. I appreciate your input.Wait, you are asking this question on a Sunday? You called Cub and you didn’t like their answer, so you asked the same question here and didn’t like the answer. Then you did your own thing and now year want to know the unit’s weight? Your luck ran out with me also.
The ride was what I noticed with mine, too. I will do some more adjusting. Been used to a JD, and, this ZTX5 is very different.While I run a ZTS2 54, I have found best pressure for me to be 14 front, 10 rear. Manual says go by sidewall, and thats what was when I picked it up. The ride was AWFUL, and I was wondering on my purchase. Once read a bit around, I dropped pressures close to above. MUCH better ride.
My ztr manual says 15 psi rear, 20 psi front. Sidewall numbers are what the tire will withstand without exploding, not what works best for the mower the tire is on. Compare your door sticker on your vehicle to your tire sidewall. They will not be the same.I take the pressure rating on the tire and I remove 3 psi. I like a comfortable ride. It helps. (also helps in those soggy days when its not possible to skip mowing...underinflation helps a little to prevent those deep "sharp" grooves in soggy soil/lawn. On the "mini bush hog" (a vintage dixie chopper silver eagle), I installed no flat solid rubber front tires. Never have to deal with a flat and they have lasted now for almost 7 years with little wear....(i use the dixie for seriously heavy bush mowing...no other machine matches it's short blade power! (48 inch deck of death, powered with a 27 HP generac engine!)
go with the tire rating.
