It's frightening to find out that 200,000 lawn-mower accidents happen each year in the U.S. Of that number, 16,000 happen to children. These are preventable accidents, or so the site says.
I see other threads in this forum about mower accidents. Let me go straight to the tips on how to prevent them to happen to children:
Source: Children Often Victims Of Lawn Mower Accidents
- Children should be at least 12-years-old before they operate any lawn mower, and at least 16- years-old for a ride-on mower.
- Children should never be passengers on ride-on mowers.
- Always wear sturdy shoes while mowing - not sandals.
- Young children should be at a safe distance from the area you are mowing.
- Pick up stones, toys and debris from the lawn to prevent injuries from flying objects.
- Always wear eye and hearing protection.
- Use a mower with a control that stops it from moving forward if the handle is released.
- Never pull backward or mow in reverse unless absolutely necessary - carefully look for others behind you when you do.
- Start and refuel mowers outdoors - not in a garage. Refuel with the motor turned off and cool.
- Blade settings should be set by an adult only.
- Wait for blades to stop completely before removing the grass catcher, unclogging the discharge chute, or crossing gravel roads. (As a safety feature, some newer models have a blade/brake clutch that stops the blade each time the operator releases the handle.)
