Timecutter Dead
Wombat63
Hi, I'm hoping someone can help me, I have a Timecutter model 75744 and was using it the other day no issues, then all of a sudden it just stopped, all fluids are ok, power in the battery, solenoid is ok, but it feels like the right side handle has no resistance when I move it inwards, it just "flops" there is definite resistance when I move the left handle in? I've checked eveything I can but cannot figure it out. Any help or suggestions would be greatly appreciated. I did check the brake sensor by having the keyt turned on and moving the handles but go no noise at all. Thanks
MParr
The brake control modules are a common problem on these mowers.
The safety switches are also problematic. There are switches near the base of both steering handles. The seat switch is another place to look.
As for the looseness in one steering handle. Make sure everything is fastened properly and check the steering damper. The damper looks like a small shock absorber. It's attached to the steering handle.
