ILENGINE and mmf103,
Scag is still using the keyswitch for the path of the charging system output. Under recommendation from both ILENGINE and a buddy at Briggs & Stratton, I have disconnected the yellow wire from the keyswitch, insulated it and rewired the charging system output from the keyswitch side of the charging system fuse directly to the battery terminal on the start solenoid. This removes the keyswitch, the engine harness connector and several other electrical connectors from the electrical path of the charging system output.
For a while I have had a small digital voltmeter temporarily installed on my Scag Tiger Cub and I have noticed a slight increase in system voltage during machine operation since I rewired the charging system output directly to the battery and I'm happy with this.
Scag has finally started to update their electrical systems, but so far only on their line of Freedom Z and Liberty Z machines.
The charging system voltage affects the hourmeter on some Scag machines as when the system voltage drops below the threshold voltage of the hourmeter it stops clocking time although the battery is still getting sufficient voltage to charge it and keep the clutch operating properly.
Just some thoughts from Mad Mackie in CT:smile::biggrin::laughing:
