Engine started running rough, wouldn't recover from load on tall grass without jerking the machine or disengaging the blades. Changed the fuel filter. The coil was weak, so I changed that and plugs, great spark, still won't run on cylinder 2 alone. Slight misfires when throttling up and down quickly. Adjusted the valves, still won't run. Brought it in because I don't go much further than that, figuring it is a compression problem, gasket or worse.
Service department calls and says it is in the fuel system. I asked if they checked compression and why would one cylinder runs seemingly fine, but the other doesn't if it was the carb. Just wondering what y'all might think.
Thanks
TJ
Thanks
TJ
