I have a new tiger cat with just under 10 hours. I have mowed three or four times with one of those times being about 5 acres of mowing.
Today, in the middle of mowing, after about an hour of use, the mower started giving me problems. When going forward the engine would start to die, or would sound bogged down. The check engine light would come on also. This happens regardless of blade engagement or not. I was able to keep it going at a low speed to get it trailered, however any speed other than little throttle would cause the problem to kick in. Any ideas before I haul it back to the dealer 2 hours away?
