I'm wanting to grease the caster spindle bearings on my Tiger Cat and I see Scag recommends a tool to replace the caps.
Before I remove I I'm wondering if that's actually necessary to replace the caps?
Other option is drilling small hole in the cap so I can see when enough grease is added. But that would make me worry about contaminating the bearings eventually. Though I suppose some silicone would prevent.
