Throwing deck belt
sdpaversr
I have a 2009 LT1050 that I can't keep the mower deck belt on. I took it to a repair shop where they replaced all pulleys and spindles plus put a stronger tension spring on and it still wants to throw the belt off. Any suggestions?
Check the moving idler arm for excess play.
SeniorCitizen
That's the experience I've had with idlers . The stronger spring may have actually made the condition worse. Kill the engine with the pto engaged then take a look at the idler position to see if that sheave is parallel with the stationary pulleys .
