Throttle Pedal Assembly
Vilderosa
I have a 2006 21hp Yard Machine lawn tractor. Over time the tension springs for the throttle pedal have snapped and I cannot read the schematic drawings from the MTD manual on where the springs need to attach. If I can just get a picture of the underbelly of this tractor it would be a 5 minute fix. Unfortunately, now the tractor is useless as the accelerator does not function. I would appreciate a photo if possible.
e.mail: vildvalley@hotmail.com
Thank you
stang8689
should just attach to the pedal then to the center pulley, the one that moves and puts pressure on the belt
