Island Life68
- Jul 6, 2019
- 1
- 3
Hi folks,
A couple of weeks ago, the belt which drives the blade snapped and yet was in very good condition... I ordered a new one and when fitting it, I discovered a damaged spring lying on top of a pulley and a broken cable still attached to the front of the frame. In fact, I'm pretty sure that the belt got cut by the cable when it broke. I had no idea where the spring was supposed to go and where the cable was supposed to be attached to... I decided not to bother with either, fitted the new belt and gave the mower a spin... Everything seems to be running smoothly apart from one thing... As soon as the engine turns, the blade engages. Safety-wise, it's far from ideal and I suspect the missing spring and cable have something to do with the problem. Has this happened to anyone on LawnWorld? Thank you in advance for your help.:thumbsup:
