BACKGROUND: In another thread I wondered again about blade balancing after sharpening. No need here to balance was ever indicated with the Craftsman defined "bolt" method. I had not seen a blade sharpener so started from scratch (well this is not exactly new). The bearing blade balancer below is so simple and easy to make it could be dismissed as "foolery." It is not, and will detect imbalance of 1/8 oz, maybe less. The device as show works on the Craftsman DYT 4000 Intek 24, blade pn MB 247 180054. With minor mods it should fit others.
The second pic is the unbalanced blade brought to balance with a 1/4 oz lead weight on a thin wire hook. Hard to see. :smile:
