Tecumsen Overhead Valve, Need some Help
LakeRat1
I have a 6 HP Tecumsen OHV Motor, ( ENDURO ) Spec. 7117 E -- Engine Family 2TPXS. 195B I pulled the bowl off the carb to clean it out, I didn't notice which way I took it off, which way does the flat off set in the bottom of the Bowl go, or does it make any difference? I figure it does,
This engine is on a Cyclone Yard Rake
Thanks for any help You'll can give me,
LakeRat1
i don't remember without going to look if the flat side is the shallow side or the deep side. But any way the deep side of the bowl goes 180 from the float pin. Most of the tec bowls have a dimple in the bottom. That is the side that faces opposite the float pin.
LakeRat1
Thanks ILENGINE, That answered My Question, and solved my Problem,
Thanks
LakeRat1
