Tecumseh plastic bowl on carburetor
mogas
Hey guys does anyone know how to properly clean (if it's possible) a Tecumseh carburetor with a plastic bowl? Or what parts are a must when rebuilding/cleaning.
briggs
photo and model number would be helpful then we can can help some of those carbs can not be rebuilt they sell the kit for them but most times the carb is wore out
mogas
Well I'm just curious in general. I worked at a local mower shop and they wouldn't let anyone clean the plastic bowls out just replace and clean the carburetor.
Even though Tecumseh offered parts for the plastic bowl carbs, they were never really meant to be cleaned, just replaced as a unit. All of the jets, and other critical parts are in the bowl, and was designed as a drop and replace bowl system, without removing the aluminum part of the carb from the engine.
mogas
Ok that's what I was looking for in conclusion just buy a bowl kit :)
