Export thread
Tecumseh Motor Help
#1
T
tothemax
Hello..
I have two tecumseh motors that I am having similar issues with. First is a 6.75 hp with a brand new carb and intake gaskets. It starts with one pull but spits every now and again while running max RPMs. I have them set at 3400. New intake gaskets. New fuel. Crank shear pin is ok. Magneto is clean and gapped accordingly. New plug.
Second motor is a 5.5 hp Tecumseh that I took the old carb apart and cleaned out everything. It had old fuel in it. Carb flowed carb cleaner.
Thoughts? I hate tecumseh motors! lol
#2
M
mechanic mark
http://www.barrettsmallengine.com/tecumseh/manuals.html
i use high test gas & a quality brand of fuel treatment per instructions on bottle when mixing in gas can. air filters ok?
#3
T
tothemax
Thanks. I read through it and didn't see anything that popped out to me..
