I doubt very much that the valve clearance is your problem. What have you done to the unit so far, to try and rem day the problem? Those engines are know around here for the swelling of the float seat, causing a lean mixture. Give us a little better picture of what you have tried and when you post back, include the spec number for the engine.
....compression relief spring?
