A little help please.
Plug gets no spark, has fuel(cleaned rebuilt carb, float bowl is on correctly too), new spark plug, has air, has fuel. No spark. I had it running after rebuilding carb for about 10 minutes, no problem. It just quit. I then replaced the Elec. ignition module as was getting no spark at all on my tester from B&S. Set gap to correct spec., still no spark. Only thing I can think of that the stop/start key wire that goes to the throttle kill switch not sure what you call it is grounded out. If grounded out, then the primary of the ign. coil (was replaced) will always be shorted and no spark. Meter on my Fluke DVM was dead so could not test for continuity.
Thus: It has good clean fuel, carb worked fine, started fluid sprayed into carb does not good, no spark. Anyone seen anything like this?
kiotikid
kiotikid
