Tecumseh Counterbalance problem
muckinfonkey
Hi all....I am new on here. I am rebuilding a 10hp tecumseh tvxl-220 it has a counterbalace in the block. I am ready to re assemble the mower after a blown connecting rod, but I am kinda stuck.
I can not remove the counterbalance shaft from the bottom end of the engine. If I can't get it out, I can't see the timing marks and that is not good. the counterbalance shafts spins, and wiggles but will not come out of the mounting end of the engine. Any help on the would be great. Thanks.
