Tecumseh Carb Interchange Question
davbell22602
Any reason why a 632334A carb wont work on HMSK85-155901A that was on a HMSK80-155478S?
Fish
If the linkages were the same, why not? That is usually the biggest problem.
davbell22602
Everything is the same except the 632334A is a non emissions carb and the 640052 is emissions carb with the plastic tube.
Fish
So the tube goes back to the air filter box area? Is this on a snowblower?
davbell22602
No, Its plastic tube thats inside the carb after removing bowl. Yes its a snowblower.
Fish
Run it!!!!
briggs
the only diff is some had a ruber o ring in there and u cant adjust the idle speed its a fixed jet
