I've got a Craftsman Snowblower (536.886261) with a 9hp Tecumseh engine (143.029003) thats having some issues. Pull start jerks back and is almost impossible to turn over without the spark plug out. Broke the teeth off the starter as well. I've ground the valves and everything is fine there and I didnt notice anything unnatural when the flywheel was off. Snowblower has only been used a few times and sat in the garage the rest of its life. Just hoping for a second opinion to see if I overlooked anything obvious. I'll probably check the compression release next and post an update soon.
