Tecumseh 4HP engine quits under full power
mcflash
I installed a new TEC 64072 carburetor on my edger. Idles fine. Under full power the engine surges, then quits. Have cleaned the new carb and put in fresh gas. Any ideas?
Catherine
LawnWorld Support
:welcome: Welcome to the forum!
:confused: I'm going to move your thread over to our small engine repair section. Someone over there may have an idea.
Have you checked the fuel flow from the tank to the carb. You symptoms suggest a restricted fuel flow that can't keep up under load.
