tecumseh 17.5 smoking bad at start up
Songer
I have a Tecumseh 17.5 that smokes bad at start up and after it burns off it fine. I'm assuming its just valve seals and if so are they difficult to put in?
Songer
Horizontal or vertical shaft, single or twin cylinder, overhead valve or L-head engine. These are all things we need to know. You can solve our problem by doing one thing, please post all engine model number, because our ESP reception is very poor on this forum.
Songer
Model MTD 13A6699H192 (17.5 OHV overhead valve) single cylinder vertical shaft
Thanks
David
Those are the tractor model numbers, we need engine model numbers!
Could be just oil seeping past the rings when not running which is somewhat common. Especially if the oil level is high.
