TB21 ED 2-Cycle Trimmer Fuel Tank Hose Detached
eddie57
Hi, the Fuel Tank Hose became detached from the fuel tank. How can I reattach the hose to the tank? I have attached a stock photo of the fuel tank. The hose that became unattached is the green colored hose. This tank was replaced 2 years ago and the trimmer has hardly been used. Thanks
dougand3
Figure out which line is which. Open the cap, dump fuel, look in tank. Use a bent coat hanger to pull line to tank opening. Is a fuel pickup (filter) attached or floating free in there? Either the blue line is the fuel supply w/ pickup on end or purge return line with just a short line connector that acts as a stop.
eddie57
I will look into it. Thanks
