Take down carburator (HR-21) lawn mower to clean it up
peteodo
  • / Take down carburator (HR-21) lawn mower to clean it up
Hi there,
I've got an old HR-21 lawn mower. I'm trying to take down the carburetor to clean it up.There are quite alot of videos of how to clean the carburator, but not how to take it off the lawn mower.
I've managed to take off pretty much all components, except for the coils and various cables that come on top od the carburetor (does that make sense?) I've highlighted these in the attached pic. Can someone advise /send tutorial/pics/video of how to do this? I don't want to go too far as I might regret it!
Thanks
Pete
I’m thinking that the intake manifold is just stuck to the gasket. Should be able to pop it loose by sticking a screwdriver into the area shown in pic 1 and pry it off. Will need to replace gasket.
tranchinh
Need to remove the bracket by remove the bolt above the light spot ,also remove the cable then slice carburetor out
